HAMANN Flash Evo M based on BMW X5M
Gesloten
BMWnewsfeed
News Feed Gebruiker
Ongelezen bericht door BMWnewsfeed »
AMANN turns the BMW X5 M (E70) into an all-wheel sports car Flash Evo M
Press Release: When you take your car for styling and tuning to HAMANN -Motorsportin Laupheim, Germany, the end result will always be amazing. This also occurred when customizing the BMW X5 M and turning it into the HAMANN Flash Evo M. Whether you need a bodykit, light alloy wheels, increased performance or visual enhancement of the interior – HAMANN makes it possible.
The BMW X5 M rolls off the assembly-line already with many exceptional attributes that give it a sense of a sports car. HAMANN dresses up this genre, adding the newly developed Flash Evo M-Bodykit. From now on, a striking front spoiler will be fitted with two or four integrated LED daytime running lights, large air intakes that supply the engine as well as the brake system with fresh air.
The carbon bonnet presents itself as a perfect match and contributes with its additional air inlets and outlets to optimize the temperature inside the engine compartment. Side sill bars connect the massive fender extensions and give the X5 M a considerably higher presence. The two central tailpipes of the sport exhaust system are integrated into the diffuser that is installed into the rear spoiler. The carbon roof spoiler adds to the necessary downforce. Even the exterior mirror heads present themselves in a stylish black carbon fibre.
Upon request, several 22 or 23 inch light alloy wheels amplify effectively the sporty appearance of the HAMANN Flash Evo M and skilfully fill in the wide wheel housings. The exclusive DESIGN UNIQUE FORGED “ANODIZED” rim, available in 23 inch with matt black anodized spokes, gives it a truly sporty appearance. The special forging technique applied makes the rim super light but at the same time offers a very high bearing load.
By using progressively wound suspension springs, HAMANN is able to lower the center of gravity of the BMW X5 M by 30 mm. This emphasizes even more the sporty appearance of the Flash Evo M bodykit.
HAMANN offers two performance improvement systems: First, the ECU is optimized by removing the factory-installed Vmax restriction of 250 km/h. Then, power is increased from 408 kW/555 hp and 680 Nm torque to an impressive 449 kW/610 hp and a torque of 780 Nm.
For an extra kick, HAMANN supplies the HM 670 sports kit. In addition to the optimization of the ECU, a rear sports muffler and catalyst replacement pipes are being used. This way, between 1500 and 5650 RPM, the torque is increased to 950 Nm. According to the data sheet, 493 kW/670 hp are also available and ensure that the HAMANN Flash Evo M can reach a top speed of 300 km/h.
Stopping at these speeds requires additional safety, for which HAMANN has developed a high-performance brake system, using 405 mm diameter brake discs in front and 340 mm diameter brake discs at the rear. 6-pot callipers provide the delay at the front axle, while 4-pot callipers do their work at the rear axle. Steal flex brake lines prevent the dreaded fading during high stresses.
When checking out the interior, the first thing one will notice is the HAMANN airbag sport steering wheel and the speedometer, indicating a top speed of 320 km/h. But this is only the beginning: Upon request, the in-house saddlery shop can provide you with two-coloured, quilted leather with decorative stitching and Alcantara, as interior finish. To round it all off, an interior package is available with appliqué made of visible carbon fibre and a stainless steel sill plate with an illuminated HAMANN logo. The feet of the driver may rest on pedals and a foot rest available in optional silver or black anodized aluminium. HAMANN floor mats and a trunk mat top off the luxurious appearance.
http://www.bmwblog.com
Ad.bohne
Re: HAMANN Flash Evo M based on BMW X5M
Ongelezen bericht door Ad.bohne »
Zijn béétje gek geworden bij BMW zeker, man wat een gedrocht :ymsick:
Niet mijn ding.
Timmy
Ongelezen bericht door Timmy »
Wat hebben al die tuners toch met dat stomme carbon! X(
E38 730dA 03/1999 Orientblue
MKIV - DSP - CP600BMW mp3 player - chrome line - fondclima - active comfort seats - S EDC shocks => Bilstein B4 shocks - styling 42 rims - xenon - PDC - hydraulic trunk - SES voice recognition - ASC
Ik vind Hamann normaal gesproken wel vet, maar dit wekt vooral braakneigingen op... :ymsick: :ymsick: :ymsick:
Bartk
Ongelezen bericht door Bartk »
zeeeeeer kort samengevat, idd :ymsick: 8-} L-) @-) :-Q en X_X
MParallel
Ongelezen bericht door MParallel »
Niet mooi, in geen enkel opzicht. Hartge en Alpina hebben stijl, maar Hamann vind ik al tijden niks meer.
Gesloten
